O.K. See what you've done now?
quickjagg,
I was going to wait and reply with a definitive answer. I just finished installing the heads and cam yesterday, and ran it in. I connected a handheld tach for the run-in and lobe polishing. Good thing, since I, too, couldn't find the wire for the tach connection at the distributor. I think I may have inadvertently connected it to the EGR vacuum solenoid (DOH!).
I should know by tomorrow when I finish running the valves for hot lash again (those lobes DO get a little shorter on break-in) and tweak the carb and timing. If my memory is any good, it should be a white wire, but I'm not sure of anything any more...
Hopefully, I'll have an answer by tomorrow, or be another victim of the epidemic. Unfortunately, the photos I took before disassembly don't have a good angle on the distributor, and I cannot edetermine the wire or connector color. The schematics show a gray wire to the EGR solenoid, so I think I screwed the pooch on that one.
