leftyvette
I replaced the plug wires on my 2000 coupe and after about 3,000 miles had one wire burn through. The car started having an irregular misfire and I first thought that the wires may be the problem. I thought one may be loose (I never feel sure that I get a good contact). I also read a lot about the LS motor being notorious for burning plug wires. Therefore, I also inspect the wires for burns. I could not see or feel any burned spots. The car continued to misfire and the mileage dropped by about five miles per gallon. I took the wires off and found the burn.
Now for my question (finally!!)
Are the original aluminum heat shields (I still have them, but did not use them when I replaced the wires) better than the aftermarket "koolsox?" The original aluminum Shields look very hard to install.
