P
purple c4
HELP! started my 95 LT1 and it seemed to only run on about 7 cylinders, lost about 300 rpm and 5 miles a gallon of fuel. Still ran smooth just down a little on power and fuel mileage, changed plugs drove it about 1,000 miles still the same, changed wires, when I did the 4 wires in the right side I started the car after and it was the same, when I did the left side I started the car and it ran worse, will backfire at idle sometimes, does not run as smooth as before I changed the wires, exhaust on that side will get orange hot at pipe just before cat converter, any ideas? Plug wires are not crossed, I think my initial problem may have been a wire on that side, could I have blocked the cat converter because I drove it not running correctly? Exhaust got glowing hot after about 15 minutes of idleing on the left side only, thank you so much in advance, I'm lost.
