Uh oh - I think I heard a blatantly false statement being presented as fact again. :eyerole
Vettehead Mikey said:
There's two of the most common urban legends of these widgets. They DO NOT provide a hotter spark, or make your engine burn cleaner.
This is a completely erroneous statement. :ugh It a fact is that an electronic ignition system with no other changes produces both a HOTTER and FATTER spark energy. That's basic physics and electronics and while we can all be impressed by the flat earth society's tenacity - the fundamental verifiable physical properties of an IC ignition system of either sort does not change.
They simply substitute an electronic 'switch' for the mechanical switch (the points and condenser). The 'strength' of the ensuing spark is a function of the coil, which remains unchanged.
This statement underscores a fundamental lack of understanding as to how a coil induces a current thru the collapse (switch) of a field and the significant role an electronic vs mechanical switch plays in this process. First the mechanical switch is replacd by a magnetic induction ring (HEI, Pertronix, Accell) or other similar mechanism as used by Mallory, MSD etc. Once the signal is generated by the ring, the actual switching occurs in the electronic module (HEI, Pertronix, MSD, whatever...). Actually points can even be used to trigger an electronic ignition - they use far less current and last indefinately and should not be confused with a points based system. The ability of solid state electronic switches to more precisely open and close the coil circuit much quicker than a mechanical switch ever could and thus it's ability to dramatically better control saturation times of a coil is what produces a fatter, hotter spark.
To summarize - yes a switch is replaced but no it's not so "simple" - rather the physical characteristics of such a switch make all the difference in the world as to how hot and fat the spark is which in turn should be important to early C3 owners given the leaner combustion characteristics used in engines from 68 on.
Now let's follow Mikey's logic for kicks shall we? Background junk: Back in the day GM had dual point ignition right? Why? Because collapsing the points twice induced slightly more spark energy potential out of the same coil and they needed a hotter spark for hi perf engines. Of course it was twice as much maint hassle and eventually this system was retired back in the early 60s sometime. Fast forward to the C3 era - with overly lean engine setups - ignition performance again become key to provide consistent dependable ignition in less than optimal scenarios. They needed both a hotter and fatter spark (maybe dual point and certainly HEI fit this bill) AND they needed longevity (electronic ignition rules this one).
So now we arrive at the question that Mikey should answer. Mikey asserts that electronic ignition does not produce any hotter or fatter spark than a single point (yes I know but bare with me
). We know GM produced a dual point for a hotter spark.
Therefore an ancient dual point GM distributor will produce (according to Mikey's logic, not mine) a hotter spark than an electronic ignition such as Pertronix right? :crazy
So Mikey - riddle us this: why don't all the big shot engine builders and exotic hot rodders and racers (except for classes that mandate it) run dual point ignition since by your logic that would have hotter/fatter spark?
