vettefinderjim said:If you lube the poly properly when installed, they will not squeak.
66427-450 said:There may be an advantage to poly....... but you'll need big race/sticky tires to actually generate enough load where rubber deflection is an issue.
Remember, we're talking about midyears, and you just can't get a big race tire under the fenders unless you cut the car up.
I went with all rubber except for the rear struts, and the F&R sway bar links, which are black poly.
