7
76L82
I am at my wits end with this thing...I am trying desperately trying to remove the lower ball joint on the drivers side of my 76, and man it is a royal PITA!!
My manual says to use a "puller" tool to remove the lower ball joint..easy enough. It shows an "in line" tool that actually attaches to the upper ball joints "lower" castle nut...under the upper a-arm and attaches on top of the lower ball joints upper castle nut on top of the lower a-arm...confused you didn't I...it basically is sandwiched in a line on top of the attaching nuts. It really acts as a breaker of sorts becuase you're supposed to use the tension of the bolts by turning this tool until it pops the lower joint from where it has seated.
Now the million dollar question....has anyone ever used this tool before?? It is shown in the Haynes Manual. It would seem to work a heck of lot better than the ball joint separator...read pickle fork...that I have been beating on all afternoon.
Anybody???
Anybody???
