T
tombird
My '64 Corvette has developed a rather harsh humming noise the pulsates coming from the rear. It occurs on deceleration only,on road load and acceleration it is quiet. It also does not occur with the rear end jacked up and running.
I have examined all the U joints and all are tight. I disconnected the half shafts from the rear wheel spindles and could feel no roughness or play in the bearings. There is also no play in the differential output shafts. The differential oil is at the correct level and is dark brown in color.
My theory is that after 110,000 miles the ring and pinion are worn to the point that they have become noisy. However before I spend $900 for a rebuilt differential I would like to have some concurrence.
My question is: Based on the above info what do you think and have I overlooked anything?
