KikiPhillips
Hello again, Before I put everything back together, I decided to check the Temp Gauge because before it never moved much.
So I read the Willcox tech pages on it and it says put 12v on the top post (12 o'clock) and ground the 3 o'clock post. It didn't move (wasn't suppose too) Then with 12v only and no ground suppose to peg to the right, still no movement.
As I understand it the Ohms resistor is that little tab between the ground and the un-used post (9 o'clock) but the sending / receiving post is the bottom (6 o'clock).
So do I need a new one? Any other test to make sure it's bad before buying a new one?
