- Moderator
- #1
- Joined
- Feb 25, 2002
- Messages
- 4,316
- Location
- Cleveland, Ohio
- Corvette
- ZZ4, 700R4, Steeroids rack & pinion, VB&P Brakes
So my girlfriend/fiancé said that after her business sells for a decent profit that she'd give me a gift of an upgrade to the vette.
The first thing that came to my mind was "Procharger" since that's been on my mind for a while now. But then I got to thinking what else I could do with $5-$6k or so. Besides needing a full plumbing setup for it, I'd also need to change the heads on my ZZ4 since they are currently producing 10:1 compression. I'm thinking I need somewhere in the low 9's if I'm going to force feed the engine.
Then I got to thinking, "Well, what about a new engine altogether, like the ZZ383?" that I've also had on my mind for a while. The ZZ4 is spec'd at 355HP/405Tq @ 10:1 compression. The ZZ383 is 425Hp/460Tq @ 9.7:1 comp. Not sure how much difference I'd notice.
I figure that if I go with a full engine replacement, I can sell the ZZ4 for a few bucks to offset the cost of the new engine, regardless of what I choose. I've also had a big block on my mind, but that requires more than just plug & play like a replacement small block. BUT...ya can get a fairly cheap 454 long block (cheaper than the ZZ383), decent torque with low compression and then force feed that.
So then I got to thinking...well, the ZZ4 is a good starting point for a build-up. What if I took it to a 383 or higher with OTC parts? Maybe a bore and stroke? AND a Procharger! :L
Or have someone build me a custom engine with the idea it's going to be force fed?
Other options would be to dump my 700R4 and put a 5 or 6 speed in the car. I've always said that a stick shift can make any car 'seem' faster when compared to it's automagic equivalent. I've never really been happy with the 700R4. I'm a stickshift kinda guy. The only reason I went to the R4 was because it was a good upgrade from my busted up TH350 and I couldn't afford the extra coin for the manual trans at the time. So maybe I keep my current setup and just get the manual trans that I've always wanted? (That may not be acceptable to the "other half" since she doesn't drive stickshift...yet. We're working on that. :L) And my linelock usage gets a bit trickier with a manual trans.
One of the issue I have to keep in mind and that I always tell others is that when ya increase power requirements, ya need to be sure the rest of the drivetrain is up to the task. I've heard stories about the rear end of the late C3's being weak. Thankfully with all the thrashing I've thrown at mine I've never had a problem with it *knock on fiberglass*. I'd hate to drop all the money into mo' power and then have my rear end splatter all over the street because it broke free before the tires did. Hmmm....
Thoughts from everyone?
