power door lock mounting
srs244
the deep south
1978 pace car, 04 CE convert
i am trying to un bubba-ize my 78 pace car and am restoring the entire interior of the car wall to wall, celing to floor. have looked all through the AIM and can't find a good blow up of the power door lock actuator mounting and rod connections. in addition, i could use some detailed diagram of the wireing for the actuators and the lock buttons as there doesn't seem to be the wiring inside the door that should be there for the entire assembly to function. can someone point me to a good diagram in the AIM (or elsewhere if possible too) or does someone have some pictures of the assembly on their 78??
thanks
steve
Steve,I looked in my 81AIM I found the power door lock set-up under the 'doors' section..
I would think that all the C-3s would be the same or darn close to each other...Good luck
thanks. i'll take a look there. i can find it described as part of the door assembly diagram, but so far that's about it. i was hoping to see a blown up diagram of the actuator and the rod set up and mounting.
