J
jonsflavette
The power door locks have not work for sometime. I knew it wasn't a big problem, so I put it on the back burner till today. The harness wires that plug into the push-on dummy plug are frayed and basically shot. I attributed the problem to this. I installed sodered, and used heat shrink on the 5 leads. installed new push-on plugs that go on the 5 post terminals for the power lock switch. Tried each switch to rule out bad switch, same thing. The condition of the switch seems excellent. They are definitely wired correctly. No operation. I don't see a deicated fuse for them, does anyone know where their relay is located? Any other thoughts greatly appreciated. Thanks Jon
