Ludigdrums
Just wanted to let everyone know about a little problem I fixed, that I didn't really find a fix for in a search of the threads.
My power door locks would only lock. Intermitantly, the drivers side would unlock as well. I changed the passengers side pigtail wiring because it was messed up for water leaking in the door (which I also just fixed with outer window seals). Turns out, I still had the problem, and the water messed up the switch as well. Got a new switch and voila! Everything works superb!
So, the interesting thing is, is that if one of the switches is messed up, then both won't work!
Just thought this might be able to help someone else out in advance!
Enjoy!
- Jeremy
Enjoy!
- Jeremy
