minifridge1138
Hello everyone,
I am hoping to replace my PS Control Valve this weekend. I have read the instructions and the Service manual, but still have a few questions from people that have actually done this before.
1) If I don't use a wedge or a fork, how can I remove the control valve stud from the pitman arm?
2) What is the best way to flush the system?
3) The install instructions do not mention greasing the control valve. Does that mean i should NOT grease it? I ruined my old one by over-greasing it and don't want to do that again.
4) In the adjustment procedure, i'm supposed to remove the aluminum end cap from the valve assembly and adjust the lock nut. I don't see the aluminum end cap? Where is it?
5) is there any trick or tip that might make this job easier?
