Power steering line leak
CHARLES
BOSSIER CITY LA.
1998 torch red coupe
After many days on trying to locate a leak under 1998 C5 i finally found it. The leak is coming from the power steering line that comes out of the back side of the power steering pump. It is leaking where the rubber meets the metal. I would quess this is a high pressure line. Ok heres the question whats the trick to changing this line? Do i have to remove alternator and steering pump to get to it or can i get it done from the bottom side? As always any help will be appreciated. The leak was hard to find because i quess it was spraying on the belt and getting slung everywhere.( no wonder my belt quit squeaking.)
