69ttop502
These are off a 72 Coupe.
1. Driver side power window motor. Works great and all gear teeth are there and in good shape. Only flaw is one of the spade terminals on motor has half missing but there is still enough there to catch on harness. $75.00
2. Passenger side power window motor. Works great and all teeth and gears are $75.00
3. Drivers side power window regulator with the 3 channels. Gear teeth are good and it bench tested good. $100.00 with channels or 75.00 without.
4. Passenger side regulator with channels. Bench tested good with teeth of gears in good shape. $100.00 with channels or 75.00 without.
5. Drivers side door glass from a coupe. Original glass with date code YN. Good shape with minor scratches from window going up and down. Top edge is great with no chips. $125.00 pickup only.
6. Passenger door glass from a coupe. Original glass with date code of YN. Minor scratches and edge is great. $125.00 pickup only.
7. Passenger coupe power window door. Only surface rust on window edge. None on bottom, very solid. Good skin but lightly separating on one corner. Motor cover included. $75.00 pickup only.
8. Driver side coupe power window door. Minor surface rust on top. Very solid and good skin. Power window motor cover included. $75.00 pickup only.
