M
Mark'syellow80
Hello Everyone,
Well I just had her repainted (it took five weeks; but she looks GREAT!!) and on the drive home last week I was feeling real good driving her when the problems started!! Nothing too serious...I heard this strange intermittent squal/grind noise and pulled into the drive and raised the hood. After a couple minutes listening and watching...........I thought .....I KNOW that noise.....water pump going bad!! Shut her off and looked on the floor.....small puddle of anitfreeze! Replaced the water pump (which was actually real bad) and while I was in there......replaced the AIR pump, power steering pump and all the belts. Now on to the problem at hand.
I did a search on the power window topic and got some good info but here is my problem: the power windows will go up and down when they want to! Hit the drivers side switch the window may or may not go up or down.....same for the passenger side window. Keep playing with the switches.....may or may not work....totally random. When they do work the windows go up and down pretty fast like they always did. I am hoping that it is just the switches but I am wondering why they both would go bad at the same time?? Are they interconnected somehow that if one goes bad they both will not work? Or is it more likely that the relay is the culprit? I am certain that I am not the only one who has had this problem! Just want everyones opinion before I tear the console apart. Thanks to all!!
MARK
MARK
