H
heider85
I have finally figured out what I am going to paint my car. What kind of paint should I go with? Am I better off with PPG or DuPont. I can get about a 50% discount with the Dupont.
They are both very good paint manufacturers.Ive used PPG alot but used to use dupont a long time ago.The best advice I can give is to use compatible products all from the same paint system.Just because they come from the same manufacturer doesnt mean they come from the same system.use an epoxy primer,urethane surfacer and urethane topcoats and you cant go wrong.heider85 said:I have finally figured out what I am going to paint my car. What kind of paint should I go with? Am I better off with PPG or DuPont. I can get about a 50% discount with the Dupont.
heider85 said:I want to paint the wheel wells and underside of my car, however, if I drive the car at all the paint is going to chip pretty bad. Is there any kind of coating or something I can put on it to stop it from chipping and keep it show material. Otherwise I am just going to undercoat it black. I think that painting it would be sweet but I still want to drive the car.
