- Admin
- #1
From http://www.gminsidenews.com
6 Speed
The 2005 Corvette comes standard with the Tremec T56 six-speed manual. The Hydra-Matic 4L65-E four-speed automatic is optional.
The revised Tremec gear box added proprietary technology not offered elsewhere on high-performance transmissions. The six-speed transmission has revised gearing when selected with the Z51 performance option. With the Z51, the Tremec is tailored with numerically higher gears to improve acceleration. Also, a lower fifth gear gives the Z51 better fuel efficiency and a higher top speed than base models. To increase durability in sustained high-speed situations, the Z51 and the base European manual-transmission models have a transmission cooler.
Smoother shifting six-speed is more precise, with shorter overall throws. The gear shift lever is now an inch shorter, and travel for all synchronizers is reduced by 10 percent. An all-new shift linkage and shift-rail bearings contribute to a more positive, confident feel. Computer Aided Gear Selection (CAGS) continues as a fuel-economy enhancement function for the manual transmission.
Automatic option:
The available automatic transmission in the C6 is the new Hydra-Matic 4L65-E four-speed. An upgraded version of the C5’s 4L60-E, the “L65” is strengthened and revised to accommodate the LS2’s 400 lb.-ft. of torque.
To beef up the internals, a five-pinion planetary gear set was added – replacing a four-pinion gear set. The extra gear reduces friction and loads carried by all the gears. The washers between the gear sets are made from Teflon, allowing optimal operation at high speed.
For protection from the high temperatures that are generated by high speed, a four-plate oil cooler has been added. When the transmission fluid reaches 127 degrees Celsius (approximately 260 F), the torque converter lock does not disengage, except briefly during shifts. This prevents fluid shear in the torque converter from adding heat to the transmission.
The 4L65-E uses a highly advanced electronic controller that has been specifically calibrated for Performance Algorithm Shifting. This technology automatically selects the optimal gear for a given driving condition, making it a willing accomplice for performance driving and hard cornering. The 4L65-E transmission shifts at higher rpm, compared to the C5’s 4L60-E, to take advantage of the LS2’s higher horsepower and rev range.
6 Speed
Automatic option:
