B
Blue Buick
I recently purchased a 1977 L-48 and the drivers window would not roll down. I checked and had power to the motor so I pulled the motor with the intention of replacing it. When I got it out I used jumper wires and hooked it to the battery. It worked fine both ways. Thinking it was a dirty connenction I cleaned what I could hooked the motor to its connection without installing it and when grounded it worked good both ways, problem solved. I reinstalled motor and it worked good in the garage. Took car down the block put window up and it would not go down. I had a new switch so decided to change that, once again the window worked great in my garage. This morning I started the car put the window up and it would not go down. It seems to not work when the engine is running but turning off the engine does not solve the problem by it self. The motor is old and that will be my next exchange unless anyone has some reason that starting the car prevents the window from working properly.
