toppthat
Im trying to decide if my ls7 can handle adding a procharger to my 120hp. over stock. I realise stock clutch wont be enough. But will i have some other problems? Im trying to get a non biased opinoin
Thanks . Im gonna do it right. And im looking for a legal/local way for speed and i heard about events at airstrips,helmet only.You're not going to get an additional 120-hp with 4-4.5lbs boost.
As I said...if you want a useful increase in performance and wish to get there with a boosted engine, you need to lower the compression ratio and go to forged pistons...especially, if by "1/2-mi" you mean half-mile drag racing or acceleration testing.
You said previously, you're thinking about running half-mile events held on airport courses.
If that's the intended use, you need the engine to be reliable for long periods of time at wide open throttle/high rpm at the 620-650-hp level.
At that power level and duty cycle, the engine simply will not be reliable with stock compression and cast pistons. The boost plus the high compression will have the engine in significant detonation. Even if you run high enough octane and retarded spark to keep the engine out of detonation, the heat you'll put in the combustion chambers will destroy a cast piston.
To be reliable and durable at that power level for sustained WOT, you have to change pistons.
I'll add that you're likely going to have to make some significant changes to the car's cooling as well to keep both the engine and the blower's charge air cooler cool.
I'm not as certain of disaster as HIB, but a half mile run may be at the edge of really pushing your luck. Twenty to twenty five seconds of WOT is do-able, but leaves no margin, and I wouldn't want to do it very often. Feel lucky?
As others have noted, a quarter mile blown Z seems to work pretty well, but you can't stress that big, little motor forever. Going with Hi's advice is certainly right for the long run.
