IH2LOSE
- Joined
- May 24, 2001
- Messages
- 3,908
- Location
- We Will All Meet Again
- Corvette
- 1966,and a 1962 thats almost complete
So I have said it 100 times I have been working on cars forever.
Well I have been having troubles removing my door strikers on my 62.The bolts were rotted fast I decided I was going to drill off the heads of the screws and then remove them with a stud remover.
I been soaking them in WD-40 (which until recently thought was a penertrating oil) Any ways no mater what I worked on and it was rusty I would always pre soak something with wd-40 way before I got to work (Barry listen in because I know you have to remove your seats for carlilse) any ways these bolts/screws would not come out. Because they were so tight to the body I just could not tourch them I had to actually install a set of vice grips and tourch the vice grips to cherry the screws/bolts (conductive heat) and all that happened was the vise grip twisted off about 3/8 of an inch of the screw/bolt
NOTHING budged these srews/bolts .I had given up and decided to drill them and tap them and I had plans for doing this some time in the near future.
Eather here or on the NCRS board I have heard mention of a penertrating oil called PB blaster .The only problem was i could never find it .Today I was at my local auto parts store and up on the counter was a can of PB.This is a place I am in at least once a week for the past couple of years and I never seen it there.
So I ran home at lunch and gave it a squirt, wrapped it with the hammer to let the oil get in. Gave it another squirt when I got home from work. before coming from the garage for the night I figured I would give it another squirt for the night.Well I decided I would try and wiggle the screw a tad with a set of water pump pleirs to let the oil get in and what do you know the screw was loose and I almost backed it out with my fingers. This stuff works like magic.Boy could I have used this on my trailing arms on the 66.
I was so impressed with this product I had to share it with you guys.I am going to bring all of my wd-40 to work for other to use. And will never be with out this product again.If you have any rusted bolts find this product and use it.
it really worked like magic,
I cant tell you how many hours I have invested in removing these screws/bolts.If some one had said the would sell me a magic oil to remove the screws I would have paid at least 100.00 for it
