- Staff
- #1
Corvette Dealers are finally receiving their 2021 Corvette allocation numbers for May and June which should see production run through the month of August
Consensus opens today and early this morning, Corvette dealers are learning what their final allocation numbers will be for the months of May and June. According to the consensus notes, orders placed for the next two months should see production around the week of August 6th with a notation stating that "estimated shipments are controlled".The allocation numbers dealers can expect to see are based on the current manufacturing rate at the Bowling Green Corvette Assembly Plant as well as the current environment. Given the continued uncertainty in the supply chain, the allocation numbers given to dealers for the month in June are NOT set in stone. While allocation numbers for the month of May should be set, the final allocation number for June is only an estimate given to dealers.
Full Story:
Production of the 2021 Corvette to Run Into August - Corvette Action Center
Corvette Dealers are finally receiving their 2021 Corvette allocation numbers for May and June with production running into August.
www.corvetteactioncenter.com
