John Mcgraw
- Joined
- Feb 18, 2003
- Messages
- 816
- Location
- Austin Tx
- Corvette
- 1960 Roman red, 1959 resto-rod, 1965 resto-rod
As promised, here are some pics of the completed instrument cluster for the 59.
The original lower cluster made it impossible to use aftermarket analog gauges, and the Dakota Digital route was not the look that I wanted, so I set about fabricating a new lower cluster that at least kept the spirit of the original one.
In the first photo, you will see the wooden plug that I carved, smoothed and finished in order to pull a mold from it. In the second photo, you will see the mold that I made and a final part, which was cast, from the mold. The rest of the photos show the completed instrument cluster fully assembled with gauges in it.
I used Classic Instruments "American Classic" series of gauges with LED indicators for the turn signals and high beam indicator. I fabricated an aluminum back plate to mount the upper gauges on and finished the plate with a satin finish black urethane. You will notice that I took some liberties with the original design by making the steering column a pass-through design rather than the open bottom with a filler plate like the original. This will make for a clean finished look, and since I am using an Ididit column, it will not present a problem installing it. Corvettes through 57 used the same pass-through style on the steering column, but were discontinued due to problems installing and removing the steering box/column. I also did not replicate the twin bullet style on the small gauge mounting. I made some polished billet bezels that replicated the look, but was not happy with the final look, so I ditched them.
I have not drilled the mounting holes for the switches yet, and will not do so until the wiring goes in, but I will be using some real nice billet knobs from Ron Francis wiring on all the dash switches as well as the AC and heat controls.
I love the Classic Instruments gauges, and the pics do not do them justice!
The quality and craftsmanship are top notch. The added advantage of this lower cluster, is that it allows the steering hub and wheel move almost 2" closer to the dash allowing for more clearance. This coupled with the Ididit column and a 15" steering wheel and seats that sit almost 3" closer to the floor, should make for a car that is much easier for a big guy like me to get into!
Regards, John McGraw
http://www.villagephotos.com/pubbrowse.asp?selected=864856
