Grand Rapids,
I am going to assume that you have a 12 volt test light.
Without unplugging the distributor cap turn the 4 hold downs and lift it off.
KOEO (key on, engine off)
With the test light connected to ground, back probe the connector w/12 gauge wire-it should light
If it does back probe the next cavity over, if it lights your coil is good (the windings anyways)
Now with an alligator clip type jumper wire to ground clip the other end over the discharge in the center in the cap (the pin that touches the rotor)
Move the clamp of the test light to the positive side of the battery, rapidly touch the white wire going to your ignition module if your module and coil is any good you will get the spark that you are asking for. If not module time of so check the resistance of your pick up coil - open, bad continuity good
Hope this is a good start, never tried to control an ignition coil any other way my self
Sent from my SM-N920P using Tapatalk
