You are getting some very good advice on here. The best is that which said vary your speed. That is the key in respect to the engine.
You didn't say if you had a 6spd, or A4, but check your tach next time your out driving it, at 55 MPH it is probably about 1000 RPM, barely off idle, at 75 you may be about 1500?
Very important: Easy take-offs reduce the strain on those new drivetrain components so they can learn to live and work together.
2nd Most Important: Try to plan ahead for easy stops to allow the brake pads and rotors to get aquainted gracefully, not in a panic.
Believe it or not short trips that get the operating temps up to their normal levels followed by a substantial cooling period is the best thing. This is called cycling, and what actually happens is the metals expand when subjected to a run cycle that gets everything up to normal temperature for about 30 minutes, then fully contract during the cooling period.
It takes approximately 7000 miles of cycling for the metals in a new engine to reap the benefits of the synthetic oil. But you don't have to baby it for 7000 miles, 500 - 1000 is what I usually use as the rule of thumb, with 500 being the minimum.
Now many will quickly argue the next point, that is when should you change the oil for the first time.... that all depends on how deep your pockets are.
I usually shoot for about 3000 miles for the first oil/filter change, although I doubt if going until the "change oil now" light illuminates would have any substantial effect on the life of your engine.
Many will say change it at 500 miles, some at 1000 miles, to get rid of the "break-in" oil. The oil that comes in a new Corvette is not a special break-in oil, it is Mobil1 5W-30.
I would say, the price of Mobil1 is a little steep for me to dump out at 500 miles or even 1000. The better idea is to change the filter and top off what is lost from the filter. Then change the oil at the recommended intervals.
Well, as usual I got rather long winded on what should have been a short answer.
Best of luck with the new vette, and drive it, that's the best thing for these cars.
vettepilot
