I
IndyPaceCar78
Greetings!
I've been trying to diagnose a crazy turn signal, and wanted to see if anyone else has ever had the same symptoms, and what the fix was.
1st off, what kind of engineer designed the C4 ('87) where you have to go under the car, and behind the license plate to replace a tail light bulb? We really must love these cars!!!
My right turn signal stays illuminated, and does not blink, but sometimes does sporatically. I've removed the culprit bulb, (inside right rear) and replaced, then removed and made sure it was seated properly in the socket, but it still doesn't blink properly. I also checked all the fuses, and the right, front bulb too. The left signals work fine.... After checking the owners manual, I couldn't see anything else it could be. When it does flash, all the bulbs work.
Any suggestions?
Thanks!
Indy:confused
Any suggestions?
Thanks!
Indy:confused
