L
LowRumble
Hi guys...I need your opinions on this, as I'm still learning as I go:
I always kept the fuse pulled that powered the clock, radio, and courtesy lights in my '76 because my battery would drain pretty quickly from the clock constantly running. I just installed a new stereo system, however, including an amp. So, now I have the fuse installed again and within 10 days of sitting in the garage, the battery drained.
So my question is this: what would you do in this situation? Would you pull the fuse everytime you were done using the car and put it back in every time you fire it up? Or, would you install the battery disconnector switch instead and just disconnect the switch when you were done using the car and hook it back up when starting it up again? I'll usually go 1-2 weeks in between starting it up, if that matters at all.
Here's a link to a picture of the disconnect switch I own:
Amazon.com: Moroso 74103 Battery Terminal Disconnect Switch: Automotive
Also, because the amp is hooked up to the battery, does anybody know if I can even use this battery disconnect switch, since there are now two separate cables going to the negative terminal?
Thanks for the help!
--Frank
http://ecx.images-amazon.com/images/I/317RTZ7F7GL._SL500_AA280_.jpg
--Frank
