Dave's LT-1
1970 LT-1 if real and worth restoring?
Hi, This is my first posting and I find the information about 1970 LT-1's extremely helpful on trying to decode a car to tell if it's the real deal. I recently came across a 1970 convert and the guy that owns it has very little information on it. First red flag. Some of the numbers are good, still checking others. The car was a late 1970 build #14000 +, trim tag indicates July 02. What would a likely correct engine suffix be, CTK, CTR or CTU? Also in talking to other LT-1 owners they say those cars were mostly if not all transistor ignition and should have a pulse amplification box, or at least the three holes where it was, mounted to the front of the drivers side front wheelwell, and this car doesn't. Another red flag. I don't know if that means it never had it or the fender has been replaced. I can tell the drivers side rear quarter has been replaced but the frame looks o.k. I need to go back and get cylinder head and carb.#s. I was able to peek down the left side of the gas tank filler, I pulled the rubber back a little to see the remnants of a tank sticker, however it was covered in dirt, dust so I could'nt read it even with a mirror. I will try again but I'm wondering if this is all worth it. The car would need a body off, or frame off restoration to bring it back. He's asking $15K as is. I was glad to see replacement parts are available because it doesn't have the right alternator, distributer, and other things.
