S
sscam69
Well if you guys have been keeping up with the performer vs weiand post you know that I am in the process of purchasing a camshaft. Well I am about to at least. My pops decided to donate a camshaft, instead of heads, to "My Project" fund:L.
This is going to be the first time I do something like this but I have a pretty good idea of what I need to do.
Do you guys with experience have any words of wisdom/warnings of pitfalls/suggestions in tackling something like this?
I am going with the XE268H from Comp Cams. What do you think? Know of a better cam, maybe from Lunati? Pending the size of the springs on the heads (going to check before I order).
I am going to remove the manifold and I think I am going to replace it with a dual plane for better low end especially with a cam like that.
I am going to tackle this job in 3 Phases. Why? because I don't have a garage to work in so I need to have good weather in order to do it. I don't want to leave the engine exposed more than necessary to swap the cam and lifters and throw on that manifold. So....
Phase 1 (Day 1)
Prop up the car on ramps disconnect Battery/ alternator/air compressor (air con.)/radiator/condensor etc. I want to remove everything that is necessary for the swap except the manifold and timing cover. This includes removing the balancer and loosening rockers.
Phase 2(Day 2)
At this point the only thing I have to do is unbolt the oil pan, timing cover and the manifold. Like stated I don't want to expose the engine to the atmo. more than necessary so I will
1. unbolt manifold
2. remove lifters and place manifold back on top (to protect).
3. swap cam, replace rods/lifters (new of course) & replace manifold.
4. put in rockers & set valve lash replace balancer and set distributor
Phase 3(Day 3)
On the final day it will be just a matter of bolting back up all the exterior stuff. Alternator/ Radiator etc etc..... Break in cam for 20 min @2K rpm
Phase 4(Day 3)
BURN RUBBER!!!:L
Questions
1. Kinda worried about that balancer. I had the crank exterior balanced when the rebuild was done. Now the timing mark is off so I am assuming that the balancer has spun. Lining up this balancer with the timing mark at TDC on compression should technically put the balancer back in its original position when it was balanced right? I am thinking that even though it has spun it will still be out of balance because of the two independent masses. Will this inbalance be negligable at 2.5K rpm?
2. What do I have to do for the fuel pump. How is the rod suppose to line up or in what position is it suppose to be in?
Thanks again for any help anybody can provide.
Frank
Phase 1 (Day 1)
Phase 2(Day 2)
1. unbolt manifold
Phase 3(Day 3)
Phase 4(Day 3)
BURN RUBBER!!!:L
Questions
Frank
