Mako
sscam69 said:Well here it is!
Well cool
Make sure you read the instructions in that cam kit and follow them carefully. don't be shy with the cam lube on the journals and the lobes either.
CYa!
Mako
sscam69 said:Ok what happened to the original plan?!
He he he. I decided to go ahead and get the cam and purchase AFR 195 street heads.
I talked to my pops about the deal and he was trying to figure out a way that we could get the whole setup at once. The he said
"can't you get some heads for $200 or something (not serious of course)"
and I tell him
"yeah right you can't even get some replacement heads for that much!"
So he says "well I'll help you out with the cam and the necessary parts to do the swap, but the heads will have to wait"
He says " but there is on point to put that kind of cam w/o good heads"
I said "yeah I know but I would rather put the cam and buy the best heads, and just put up with the stock heads until I have the money for them"
He said "alright then"
so thats the plan. I am going to go with the AFR heads. I even looked up a combo with this cam (XE268)/Heads (AFR 195)/ and intake (Performer RPM) and the output was something like 420Hp@6K/ over 400ftlbs @4.5K
I hope to have a job pretty soon, and I mean a REAL job as a manufacturing engineer locally. I applied for a manufacturing job today and I was told they were hiring and as awkward as it sounds when I got home and checked my email I was sent an email by Honda R&D. So right now I have my fingers crossed. When I get a real job then I will purchase the heads.
:confused Their 100% I/E/chamber CNC ported.FWIW, AFR's require porting, they rarely if ever in my experience flow the advertised numbers right out of the box
They've been independently tested and flowed at or more than specified.rarely if ever in my experience flow the advertised numbers right out of the box
They'll cost about $800 to get them to "Truly bolt on" to a SBC. I am confused though on those heads. The have pressed in studs and the lift is limited by which one. The spring or the fact its got a pressed in stud?:confused. I called SDPC about the heads and they just swap the springs and say they can handle .55" lift:confused I thought the lift was limited by the pressed in stud. Their the next best thing to AFR.The Vortec heads have a lot going for them and they will run properly out of the box
I know, by that time I'll have a real job and probably pull the engine and build it myself so I know exactly whats been done to it and use the necessary gaskets/parts. I couldn't do the initial rebuild myself because ofUnfortunately the head gaskets in that kit are likely not correct for aluminum heads
Yeah I know but I also agree with your methodology. I figured since the combo has been proven and the heads (AFR) have the flow to support the cam, why not?I know your excited to get this project moving, but with due respect, your kinda going at it bassackwards.
Already taken into considerationYou then select a valve spring compatible with the cam lift and rev range your going to run. Bad things will happen if Mr. Valve meets Mr. Piston.
I don't think the S/R torqurers are all that great for what I am shooting for. At least out of the box. Yeah I can get them ported but to get a 'TRULY' good porting job by an experienced person is going to cost me the same or less as going with the AFR heads that are already ported.I'm still of the opinion a pair of S/R Torquer is the way you should go
sscam69 said::confused Their 100% I/E/chamber CNC ported.
1. Lack of tools
2. In the middle of semester and school was VERY VERY time consuming
3. Lack of funds to make mistakes
4. Needed a daily driver quick and didn't have the luxury of putting together a high performance engine.
The power increased from running a higher compression even with the energy being extracted by the aluminum material is better than the lower compression with more heat being retained in with iron heads. At least thats my experience.
The AFR heads are an investment for me. I will be using these heads on a 400ci engine with a small blower on it and I was going to use the methodolgy you explained above i.e. call up cam manufactuers etc. to help me meet my goals.
There is no point buying two sets of heads when I really only want one![]()
ad details to come.
ad
ad.
ad
ad and was having trouble bolting on the new intake manifold
ad
ad.
ad. Like the saying goes "if you want something done right, do it yourself".
