I
igasper10
Well I wanted to rebuild my Q-Jet 4MV out of my 74, so I took everything apart, cleaned it, replaced a few things and now of course... I can't remember how everything goes back together!!! I've got it all figured out except for how the fast idle cam, cam follower, fast idle lever, and the secondary lockout lever all go together with the little spring holding tension on the fast idle lever and cam follower. Any diagrams or pictures that you know of showing the assembly of these components would be greatly appreciated! Again, any pictures of the choke side of the throttle plate put together are needed. Thanx in advance guys!
ian
ian
