RfirstVette
Active member
do they work and do i need one ? octane around here only gets up around 91 . My car has a 350 .30 over , aluminum heads ( 64cc) pro-flo fuelinjection.
Thanks,
Gary
Thanks,
Gary
First ... siphon-out & dump or drive off that 2-year-old gas. If you're gonna run the old gas, do get some gas dryer from parts store. Or go to drug store and get two (2) one-pint bottles of 91% Isopropyl Alcohol and dump one bottle (16oz) in with old gas. When tank's nearly empty, dump the second bottle in as you fill up with fresh 91 octane gas. DO NOT bother with 70% alcohol ... 70% iso already has so much water attached to its molecules that there's no room for more ... get the 91% isopropyl. After you're into the second fillup with fresh 91 gas, then see if your spark rattle is still a problem ... if so, then look to timing. Make sure the distributor's mechanical (centrifugal) and vacuum advance systems are functioning normally and there's no vacuum leaks. If all that checks OK ... then back off the timing about 2 degrees (ie from 36 go to 34). Only back off the timing after you've checked & verified all advance systems check AOK.RfirstVette said:The reason I asked was sometimes when I stomp on the accelerator it kind of pings/rattles. So it could just be timing or something or the fact it has only been driven 500 miles in the past 2 years by the guy I bought it from. Gas probably isn't the best after that much time either I guess.
gary
