abbezr1
I have a question about what the idicator lamp should do after the the repair and before you go back a clear the code. Long story short have a code 16 left side sensor. I took everything apart cleaned contact points on sensor and frame used dilect. greese and put battery box back in. Before putting everything back together i hooked battery back up turned ing. to on position and indicator light still was on. I was under the impression that indacator light would be off but the code would still be in the derm until i cleared the code? Every post or anything on this subject says clearing the code is the hardest thing to do and takes the longest but they say that is why a dealer will replace the sensor so they dont have to clear the code. If they put a new sensor in wouldnt the code still be in the derm and have to be cleared? I just dont want to put everything back together and then have to tear back apart. It could be that the light stays on continuously until i clear the code? That is the step that is unclear on all the post and info when making the the repair. Sorry i was not trying to make this a long question or confuse anyone other that myself. thanks!!
