2
2000FRC
I have 2 (header to back flange) exhaust systems. One system I use for the track and the other for street driving. I gutted the small pup cats on one system to increase exhaust flow for track use. After driving for the "pupless" system for a few miles, I got codes P0134, P0140 (relating to insufficient activity in Bank1 sensor1-A and Bank1 sensor 2-B) and codes U1016, U1064, and U1096. Also driving back from the track I noticed my gasoline MPG was extremely low, so It appears that it is running very rich. I have reset the codes, but they come back after a while.
I replaced the "pupless" system with the other completely stock system (has its own oxygen sensors) and the codes DO NOT appear, so the problem is clearly related to the absence of the pup cats on the pipes I use for the track, and possible damage or fouling of the oxygen sensors.
I am puzzled why the sysem with no pup cats (the main cats are still there) is causing these codes and the engine to run extremely rich. The car is certified to California/Northeast emission requirements.
Do you think that I have damaged or fouled the up stream or the down stream oxygen sensors? If so is there any way to clean them so they will function properly again? Is there anyway I can use the "pupless" system on the track and not have this problem reoccur? (for instance using Simulated Oxygen sensors). If not, I'll just go back to the stock system for all my driving requirements.
I thought gutting the pups would be a good way to get a few more ponyies for the track, but this has caused more problems than benefits.
