Stan & Junk
since I'm still trying to decide which way to go here I have a few more questions........ what if the system isn't a vintage 60's but rather a late 70's (such as a '78 factory system).
would the same logic apply or are there enough differences between the 60's AC systems and a late 70"s AC system to cause a change in anything important?
Also, when I was reassembling the system when putting the car back together I changed out all but two of the O Rings with a replacement set - they are the green ones that Junk mentioned. If I decide to stick with R12 do the green O Rings need to get changed back to the original black style ones?
I understand that IF I decide to convert to R134a I'll expect the shop doing the work to have to go thru the entire system front to back and make whatever changes are needed and replace whatever parts are needed such as Junk described above so while I've always heard that R134A doesn't blow as cold (approx a 3*-5* difference compared to R12) at least I'd know the entire system had been gone thru front to back so it should at least work OK.
IF I decide to stick with R12 do I need to make sure the entire system is just as thoroughly gone thru front to back as much as a conversion simply because it was opened up and I can't expect it to be as simple as the shop refilling it with R12 and saying "here you go, your car is done"?
I should expect that because I opened the system up it would now need to have the entire system flushed, drier replaced, etc, etc whether its a conversion or not so really the labor is really basically the same on either job?
Again, back to what was one of the original questions in the thread, you and Junk gave a pretty good describtion of the R134a conversion although you two tend to disagree on the final performance results but how would I expect the Freeze 12 to perform? Somewhere between R12 and R134a in terms of coldness of the air out of the vent?
Would I need to expect the same requirements of having to have the entire system gone thru just as completely first same as a conversion if I went with Freeze 12?
sorry to drag this out and ask more questions, i just really haven't a clue what I should do.
You know, if EVERYONE all gave the same response of "do THIS" no matter which system "THIS" was it would have made this issue mush easier....... but I should have known not to expect a lot of agreement on any single issue in a forum!
