robertwilbanks
If the boiling point for water under pressure is around 240 then why does my radiator boil around 220. Also, when goes into the overflow tank doesn't it supposed to draw from the tank also?
It is an 86 and the radiator has 1989 stamped on it.
I have replaced the cap(GM), hoses, water pump, and thermostat(160).
I have cleaned the area in front of the radiator.
I added a oil cooler and mounted it so it did not block the radiator at all.
I have removed the rubber seals in the engine bay for more air flow.
The only leak I had was from the water pump but fixed that. No water loss that I can tell except boiling out.
Around town it is great. When I drive home up the mountain it hits 220+ and then starts to overflow. Turning the heater on drops the temp 10+ most times.
Once I hit the top of the mountain and start across it drops back down below 200 so over all, the system seems to work good. I just thought it should not boil at 220.
