TAC
- Joined
- Feb 18, 2002
- Messages
- 252
- Location
- Bothell, WA
- Corvette
- 1987 Yellow Callaway TT Convertible & 2003 MY Z06
I'm getting my '87 TT dyno'd next week. It's going to be done on a dyno I don't know much about. They jack the car up, remove the rear wheels and bolt on a water cooled hydraulic pump gizmo. They use hydraulics to control the pressure. It's kind of weird looking but it allows the operator to actually control the engine speed while I keep the throttle at WOT. We are going to be doing quite a lot of pulls and I'm a little worried about the stress on the engine. I've asked for several additional fans to keep things cool and the shop has offered a tank of high-performance gas.
My questions are about this gas. Should I use this gas straight...not mixed with 92 octane? Does the high-po gas cause more stress or does it allow the engine to run cooler? The shop says it will help control heat and detonation. Is this type of gas unleaded? I was thinking maybe a 50-50 split w/regular gas or maybe just use good old 92 octane Chevron. What do you think?
As long as we're on the subject I'm not sure how to tell the shop to safely jack the car. I know there are jacking points along the side of the car but I doubt the shop's jack fits into that slot. I didn't really see any way to jack under the rear end because my Y-pipe with crossover pipe blocks that effectively. Can I have them use a floor jack and put it under the X-brace (it's a convertible) right where the brace attaches to the body? Is that strong enough to be a jacking point?
Any help is appreciated.
TAC
TAC
