Tommy Almond
Just wondering what others may be seeing on temps? I have a 1981 stock with a 350/195hp GM crate motor installed. All ECM and other parts operating as was original. Today during a 80 miles run in upper 80 degrees I was having a water temp just below the 200 on the gauge and was around 220 on the oil temp. I was not running AC but was running about 65mph on interstate.
When I stopped for a few minutes at home while opening the garage when I went to refire the engine did start but was harder, had to spin out and pump gas a couple of time.
I know there is some heat build up in the engine compartment when hood is closed that could cause some of the harder starting since might be heating up the carb some but is my heat readings in normal range?
Thanks in advance for any answers.
and ask a good mechanic that question about the restart
