o2bnkc
We are looking at a 1990 ZR!. The clutch feels like it needs to be adjusted. Are these self adjusting clutches? What is the button for, that says normal power and full power? Is it supposed to be spring loaded? Thanks.
no the switch doesn't take the ignition key. there's the ignition key and the power key. the power key allows you to switch between normal and full power starting in 91 the default setting was "off" or normal power.The switch takes the ignition key and allows you to select just to run the primary injector tubes or both injectors tubes. In short, fast and faster settings. The ZR1 is a different kind of animal in FULL POWER mode. Basically you got L98 type power in Normal about 240HP in FULL POWER you got 375HP.
Not sure about the clutch but if it is set up like my 93 it is hydraulic and has no adjustments.
scott,I'd recommend getting on www.zr1.net and looking at all the info they have. I want to have a ZR-1 at some point, but it seems to be a car you need to be pretty familar with before you buy so you know what your getting.
Clutch can be expensive. Corvettes of that era came with a special flywheel that's expensive, but there are options. Fuel injectors are a common problem and pretty much need to be replanced if there are original.
The ZR-1 sounds amazing and bulletproof in a lot of ways, but it can turn into a money pit if you don't do research into what details to look for when your purchasing.
Cheers,
Scott
