S
Skant
I just got my vette back from the shop today. $950 for a new front spring. The old spring was delaminating and coming apart.
Now my vette's nose is sticking up in the air... the front of the car is up higher than the rear end! The shop tells me that it's normal, and that it will settle in a week or two. I sure hope it's true, because I feel like I'm driving a 4x4 again right now...
I thought my vette was lowered. Its front was definately lower than a normal vette. But now the shop thinks that maybe it was actually sagging because of the damaged spring, not because it was lowered. So I might be disappointed because I did like having it that low.
Where previously there was about 2.75 inches between the bottom of the front spoiler and the ground, now there's about 6.25 inches. Is it really going to 'settle' 3.5 inches lower than it is right now?
I'm hoping that it will come back down to the same height it was before, but I suspect I'm going to be disappointed.
The other thing I got to thinking about was the relative stiffness between the front and rear springs. If the front is new, and the rear is seven years old, would that affect the balance of the car?
I'm not sure how much these springs lose stiffness with age (if they really do at all). But if they lose much stiffness after seven years, then I expect I'd have a car which is more prone to understeer with a front spring that's stiffer because it's newer than the rear spring.
I'm hoping that these springs don't lose much stiffness with age so that it will still balance the way it was meant to. Otherwise I'd guess I would need to replace the rear spring as well... ick. I don't want to spend _another_ grand.
Of course, if the springs did weaken noticably with age, vettes would tend to run lower and lower and lower to the ground with each passing year. Yet their ride height doesn't change much over time, I think. So maybe significant stiffness loss in springs is something that only happens when they are very old or damaged.
- Skant
- Skant
If you wish, order the cushions with two 10" bolts for better adjustment (and lowering cabability). I'm planning to do that myself this week, and considering lowering the front as well...
