J
jmp
OK, this is mostly for curiousity's sake, but the whole solid vs. hydraulic thing kind of confuses me.
I'm not talking about which is better or why one is better, etc, but more of what are the actual, physical differences is setups. Some of my questions, I think, are going to boil down to terminology and definitions, rather than actual technical discussion.
Let me give some examples.
As far as I can tell, there's a "solid" cam setup and a "hydraulic" cam setup. Then there's the "roller" option which, I think, is available for both solid and hydraulic.
Now, we've got lifters, rockers, and the cam itself, right? Well, I can see how the rockers differ between "roller" and "???" whatever the non-roller term is. With lifters, there's solid lifters and hydraulic lifters, and I believe I understand the difference between the two. There also appears to be roller and non-roller lifters, which I'm guessing comes in both solid and hyrdraulic. Correct so far?
What about the cam? I've seen articles discussing "solid roller cams" and "solid cams", so I'm guessing that there are four different kinds of cams: solid, solid roller, hydraulic, and hydraulic roller. But where exactly do the hydraulics come in? What is "rolling" in a roller cam that is not rolling in a non-roller cam?
I'll probably have more questions after the first round of answers, so I'll leave it here for now!
