W
wolf_walker
Updated : questoins and more questions on a 74..
New guy here, who hasent gotten around to writing something for the introductions forum, so in the meantime..
Mission: Good daily driver for a woman in her late 30's that dosent want to have to replace things again.
Subject: One pretty blue 74 convertable automatic, matching numbers, base model 350, nothing really special. 100K or so on it, had been resting in a barn for a decade when I started work on it.
To date: VanSteel rear wheel bearings and matched rotors, re-welded GM's slopy crap on the T-arms, adjustable strut rods to replace the bent one's, KYB shocks all around, polyurathane everything front and rear, basicaly new everything that wears front and rear, stearing gear included(except gear box), F41 spec springs fron and rear, stock swaybar in front(for now), brakes are new from VetteBrakes except for the booster that seems fine, U-joints, lots of cleaning, tune up, compression check, more of a tune up, finally found a stupid vacume leak that had been playing havoc with the poor motor, hoses, belts, I'm sure there's more but that's all that comes to mind at the moment. It's been a long project done off and on when I had the time. The owner is a good friend obviously.
Problems:!
1. The vacume leak is from the headlights somewhere, they still work, just slowly(surprise surprise), does anyone make a kit for all the hoses and such or do I just piece one together. Are the actuators likely leaking internaly? Replace or rebuild?
2. The front and rear things that are called bumpers, since being driven finally in the last week or so have devoloped about 12 cracks between the two of them. I'm assuming patching is either not possible or not worth the effort. Anyone make especially good replacements? Any to avoid?
3. After takeing it out for it's first real drive yesterday I heard a vibration. Only on throttle, back off and it's gone, seems to continue no matter your speed or gear, it's upper middle pitched.
My first guess is ujoints, which are all new, and the thought of removeing again makes my head hurt, or the rear differential, which I havent bothered with. It was one of the things I cut corners on, figuring they dont often go out, least not on most cars. One odd note is that I would almost swear it didnt make this sound untill after I had it aligned at the GM dealer(those idiots are awhole different story).
4. This single point distributer has GOT to go, the motor is just begging for more spark. I would like to keep the original due to it haveing the mechinical tach drive(which needs a cable), I'm thinking either Mallory or Petronix conversion kit and a good hi output coil. Recomandations? Also are the stock grade wires and plugs up to the higher energy ignition? I know the HEI used different one's.
I think that's it for the moment. It's been a long and educational journey since I first saw this thing gathering dust in a barn, had sat for a decade, everything was shot. I'm still amazed to see it shining and moveing(and stoping) on it's own. I'll post more of how I got tangled up in this later...
Thanks...
Rex
Problems:!
Thanks...
Rex
