Hi fine69! Removing the front wheel bearings is a very easy job to do. Go to an auto parts or hardware store and get a brass punch 1/2" or 5/8" in diameter.
If you run your finger around the inside edge of either inner or outer bearing race, you will feel two indentations or hollowed out areas 180 degrees apart in the hub itself that were designed for the purpose of placing the punch in. Insert the punch into the hub from the opposite end from the bearing race you wish to remove. Place the punch in the hollowed out area with the end of the punch resting on the edge of the bearing race you wish to remove. Briskly hammer the punch while firmly holding the punch against the edge of the race. Alternate sides as the bearing assembly starts to move outward so that it doesnt get jammed in sideways. Methodically hammer the punch evenly on each side of the races until it just pops out of the hub. If you haven't yet removed the grease seals inserted into the hub ends right next to the bearings - this procedure will remove both the bearing, race and seal at the same time.
The purpose for using brass is that it is softer than the steel you will be working on. Brass will not mar or dent the hub in case your hammering gets a little wild or in case your punch slips. Don't be afraid to put a little mojo on the punch at least until the bearing breaks away from its seat.
I recommend that you grease pack new Timken bearings for reinstallation.
Let me know how you come out. Highest regards!
Larry Langley
Austin, Texas
