ringleader
:W Thinking of changing system to 134a as my A/C needs freon. I would be interested to know if anybody had done this and if satisfied with the car getting cold.
ringleader said::W Thinking of changing system to 134a as my A/C needs freon. I would be interested to know if anybody had done this and if satisfied with the car getting cold.
tyrel said:There are a lot of myths surrounding the conversion, "it doesn't get as cold", "it's not compatible", etc. For one thing, the corvette used the same a/c compressor from 1989-1996, the nippondenso 10pa20c, which was well into the time when R134a became commonly used. Also the same evaporator, and I fail to see the difference in the condenser, maybe more fins in the later c4 or something. About the only difference would be the o-rings, and even then the stock o-rings don't leak nearly as much as some alarmists would have you believe. Nevertheless, it's a matter of maintenance when fully servicing the a/c to change the o-rings, HNBR rings are perfect for conversions because they are even more durable then the original stock ones. The low pressure switch is adjustable, and as far as the high pressure switch, my feeling is that, as long as the system is charged correctly, it can never get too high or it'll simply vent through the compressor relief valve. If the conversion is done properly, there should be only a few degrees' difference at your vent temps than using R12. Here are some sites that might help you:
I am retired from GM engineering and worked on the conversion to R134 and we used slave R12 vehicles and converted them to R134. Our tests showed that efficency was markedly reduced until we changed the condenser & compresser. The entire package has to be changed to get good results and reliability.
I'v Been useing Freez 12 for over 5 yr's Work's Great!! Depend's on what is Wrong with System on what I Do to it!! If Just Low I Freez 12 it!! If it has a Killed Comp. I Replace Compresser,Dryer (Acclum) Flush system and Change All O-rings,Put in a new orifice tube( Ford Blue #46031) or a Smart Tube(Self Adjusting VOV valve)!! and Retro!! If customer want's it to Look non-Retrofit!! (Classic Car's)I use Freez 12. with Ford Blue or Smart tube!! I Personly Like The Smart Tube!! It works alot Better at Low Speed's or Stop & go Traffic!! Don't Get me wrong the Blue tube work's way better than stock tube and most people Can't tell the Diff!! Unless thay get in a 2 hr.Traffic Jam on a Really Hot Humid Day!! For $30.00 it's Worth it to Me!! Use 10% less Freez 12 or 134a!! Freez 12 is a mix of 134a 90% and R-12 10% Homogenized so molecule's stick together!! (Like MilK and Cream!!) If retro fitting ajust Pressure sw's!!(non-ajustable) Replace!!Moonunit 451 said:I didn't read the links provided, but I've read quite a few before. There is NO reason not to use an adequate "drop in" and save yourself a bunch of cash. This topic has been discusded many times. Oh yea, and Ive been useing Freeze 12 for 18 mos. very nice. Where is SunCR, I think it is, not that he will fully agree with me, but he knows this stuff. Do a search.
junk!!ps I replace Acclum-Dryer any Time have a System Open)................Greg Gore said:R-12 is still available if you know where to look for it (widely available on the world's largest Internet auction site). I don't know of a good reason to convert an R-12 system other than convenience. R-134 operates 90% as efficient as R-12 and in addition compessor pressures are elevated with it. R-134 will leak through porosity in conventional hoses and seals so these parts have required engineering revisions. I recently read a report that claimed more flourocarbons are released into the atmosphere from a single volcano eruption than is contained in all the world's refrigeration systems.
Regards, Greg
