Hi Got a 66 327.300 no air. I would like to change the antifreeze and flush the system. can you recommend a good flush agent and some guidelines for doing this procedure? also is a 50/50 solution such as prestone ok? thanks, vinny
A 50-50 mix of the good old "green stuff" will work just fine; so will newer coolant with the Zerex G0-5 HOAT formulation. DO NOT use "Dexcool".
I just read the installation instructions for AFR heads. It says to use distilled water as coolant. Since they're manufacturing aluminum heads, I'm thinking this is what I should be doing because of the Harrison aluminum radiator. The old helm manual doesn't make any mention of it. That said, it does make some sense. Given that water is a poor conductor of electricity, and that disolved minerals increase it, galvanic reaction (corrosion) would be more likely to occur with tap water. Additionally, living in Tucson for several years made me aware of Water Wetter, made by redline. Besides being a corrosion inhibitor, it helps with coolant temperature. Hot spots in the engine can create localized boiling, inhibiting the coolant's abilitly to carry this heat away. It helped noticably, and we all know how temps can soar in the summer in traffic.
[/QUOTE]
