68Roadster
The old radiator has given up the ghost and I opted for a new DeWitts Direct Fit aluminum as a replacement.
The car is a '68, base motor (SB) with 4 speed and Air....previous research has shown that SB's w/out air and SB's with air require several different parts. Air cars tend to take more parts that are in common with the BB cars.
Have ordered new cushions for the tanks and a foam seal kit that goes between the radiator and the core support.
My question is: Are these foam pieces glued in place to the core support and what is the proper adhesive to use? The Assy Manual is not much help and one would assume that just placing the seals in there and relying on fit to keep them in place would not suffice.
Words of wisdom would be much appreciated. Thanks in advance....
Cee
Cee
