Pepe Le Pew
What is the purpose of the rubber coupling in the steering column, right before the steering box? I think it is called "rag joint", but I'm not sure.
After my 1980 started wandering on the road a bit, I started checking the steering and found the rag joint was split and the coupling was just moving between the pins with with hardly any tension. :eek
Why is there a part that flexes in the steering system when we are trying to remove all the play in all the steering components. Is this rubber joint something I need or can I just put different bolts in the coupling and make it tight with no play. Can anyone shed some light on this for me. I'm confussed. :confused Thanks friend's!
Kenny
After my 1980 started wandering on the road a bit, I started checking the steering and found the rag joint was split and the coupling was just moving between the pins with with hardly any tension. :eek Why is there a part that flexes in the steering system when we are trying to remove all the play in all the steering components. Is this rubber joint something I need or can I just put different bolts in the coupling and make it tight with no play. Can anyone shed some light on this for me. I'm confussed. :confused Thanks friend's!
Kenny
