My hood is an L-88 "style" hood that has the L-88 type of additional 2" dome and that's all. Just LOOKS like an L-88 hood from the outside. Knowing my taller Air Gap intake would require a taller hood I bought this one but ran into trouble when I tried to run the common 14" X 3" open dropped-base air filter. I managed to reduce the height of the dropped-base by about 5/8" and had to remove 1/4" from the Air Gap's surface and finally ended up with about 1/16" hood clearance. Using my water manometer I found there is a vacuum at the base of the windshield when running an L-88 hood because the additional 2" dome pushes the air upward like an airplane wing. The manometer revealed there was no pressure until about 1/2 way up the windshield so I decided to use a frontal intake for my Ram Air. The original L-88 hoods may have had "cold air" but not "ram" air because of their additional 2" dome.
To me a "pissing contest" is a pointless argument:argue. Posting a "derogatory word" or "bashing" would be a "flamewar":flaming in my lexicon.What pissing contest? I have never said a single derogatory word against any of you even though many of you have been bashing me all along.
I'm confused.:confused I thought we were talking about Holley choke assemblies. How'd we get onto plug wires? But, ok...you say that you spliced a plug wire?!I have simply stated what I was doing and why I was doing it in my troubleshooting process to find out why I suddenly had a dead #2 cylinder. (snip)
There is no direct correlation between high gears and fuel mileage.
An Air Gap combined with a long duration cam and high gears is a disaster because runner velocity is so slow fuel drops out of suspension. When I was running the stock 3.08's my fuel mileage was a dismal 8 mpg but it shot up to 10-1/2 mpg with the lower 3.70's because the runner velocity increased. That is why the CrossFires and Tuned Ports had small diameter LONG runners to keep runner velocity high to go with the tall 2.87 gears. My Magnum cam is rated for 2200 to 6200 rpm and so I geared it to achieve 2250 rpm at 65 mph. With a near-perfect match between the torque band and the final gearing my 454" gets pretty good fuel mileage at cruising speeds. It started off at 8 mpg and it's now getting 14 mpg..................a 75% increase with about 75 more horsepower; proof that I am doing something right. And with my engine now hitting on all 8 cylinders it'll probably get 16 mpg at freeway speeds.
Huh?
There is nothing wrong with splicing a spark plug wire as long as that splice isn't close to a ground. In my case my large-diameter Ram Air filter base was hanging over the top of the front two HEI terminals and I wasn't aware of how close those terminals were to the base. The terminals now have a full inch of clearance (actually about 1-1/8") so there shouldn't be any more problems with flashing to ground. I had created the problem and once my #2 cylinder suddenly began misfiring on my coast trip I was determined to find the cause.
Apparently your #2 cylinder disagrees with your theory.![]()
I can only imagine what would happen if someone attemped to power up a house using a capacitor discharge system
Take a good look at the high-voltage power lines that stretch across the country. None of them have insulation and they are all spliced with u-clamps every several hundred feet. Or haven't you ever noticed that?
Is there such a thing as a shade tree engineer?Take a good look at the high-voltage power lines that stretch across the country. None of them have insulation and they are all spliced with u-clamps every several hundred feet. Or haven't you ever noticed that?
Wait-what?!
Now you're trying to convince us that the high-voltage, high-current AC power grid is similar to the high-voltage, low current DC power which runs through the secondary ingition system on our Vettes? Further, that we can "splice" plug wires with u-clamps?
This thread is getting a bit odd, I have to admit.
As the others have said those powerlines are totally different. AC can behave very different to DC. Plus they are sperated by several feet.
They are certainly not spliced with u-clamps either. I would imagine that they are spliced with c-crimps, which are much more secure, and conductive.
Kpic said on another thread he's not sure what i do for work. Guess what, I'm an industrial electrician. I had to learn about the power distribution system and requirements as part of my training.
Heck...I didn't think they even had electricity in New Zealand.
Not to to pick on toobroke... However, I am beginning to understand why he is too broke to retire after he rubbed my nose in it so often.
