Rapid Turn Signal
AZMike
AZ
2001 Mil. Yellow Convertible
Driving to work this morning, noticed that the right turn signal flashes really fast now. The left is normal. Is this just a burnt out bulb somewhere? Haven't had time to look yet.
Any particular bulb thats prone to burn out first? I have an 01 vert with all original bulbs.
:Steer
What he said!
This rapid flashing is your indication that a bulb is not working properly.
Okay, this is freaky. I just signed on to ask the very same question!! I did a search and didn't find this thread. Came back to the C5 forum and here it was!! I was thinking it's a bulb out, too.... but I sure can't see it. My son told me one of my driving lights was out - but then it came back on. The rapid turn signal only happens intermittently, so maybe the DL's ready to go completely out. Thanks for asking, AZMike! :w
(BTW, Mike, I've got an '01 vert, too. :D )
Mary
Mary,
The filament in your daytime running light is probably broken, and when it gets jiggled around and makes contact, it'll light up. The current flowing through it will likely hold it there unless it gets jarred pretty hard - that is until the current flow stops, like in the flashing of the turn signal.
These bulbs are fairly inexpensive and available at any auto parts store. The hard part is getting to them. If you have fairly small hands, the easiest way to get to them is to lift the hood, and turn on the headlights to lift them. Then remove the hood stop (if memory serves a 12mm wrench will do the trick). Take care not to change the position of the locking nut too much, juest loosent it about a 1/4 turn to free up the stop. With the stop removed, you can reach down and forward to find the bulb fitting. Turn it 1/4 turn to release the tabs, and pull it out. You probably won't be able to get it above the front bumber, but there's enough slack in the wires to give you room enough to change the bulb. Then put the bulb fitting back into place, replace the hood stop, and you're set.
The alternative methos involves jacking up the front of the car, and perhaps removing one front wheel, sticking your hand through the brake cooling duct, and possibly removing some additional plastic panels. Never tried that, as my hands were small enough to go from the top.
It shouldn't take more than ~15 minutes the first time you do it, and I'd bet I'll do the next one in less than 5.
Good luck.
Craig-o
Craig-o said:
Mary,
Good luck.
Craig-o
Sounds like I'll have to have my wife do the dirty work - she's got the small hands. I noticed driving out of work yesterday that I do in fact have the front right running light out. Maybe I ought to get an 'eye patch' until I can fix it. Got too many plans this weekend to get to it.
Glag I could be of help TriBlack - maybe my car has psychic bulbs or something. ;LOL
I did my first bulb replacement only about a month ago, and I, too have an '01 convertible. Maybe GM ought to issue a TSB or a recall on these as they're obviously defective ;-)
Just happened to me yesterday, front left turn signal bulb. Same symptoms.
Be careful to pry back fasteners inside bulb casing to ease out the bulb.
Te best method is to remove the housing under the flexible airdam, big hands no problem!
