Rather than burn up a new wiring harness or alternator, I'm asking advice on how to allow for the change from the old alternator/external voltage regulator to the new alternator/internal regulator.
Here's a photo and some questions:
#1 - original-style connector to alternator
#2 - new-style alternator connection
#3 - ground connector for alternator
#4 - BAT wire connected to alternator BAT connection
#5 - ground connector for original-style external regulator
#6 through #9 - old-style external regulator connector
In another thread, midyear said
I'm being cautious.
Would someone mind explaining the above paragraph using my connection numbers in the photo?An internal reg alt will bolt directly in place of the external reg alt. If you use a GM style from a parts house, you will use your large red wire, and only one of the existing small wires.
The wire plug on the alt uses 2 wires, the wire farthest away from the main bat term on the alt can be run right back to the main bat term on the alt.
The other wire is a key on trigger wire. I use one of the existing wires, trace it back to the regulator plug, clip it and tie it into the key on wire already present at the same regulator plug. then you can eliminate the plug and tape up remaining wires neatly for a factory looking install.
I'm being cautious.
